CellPro Multi 4 question
  • CellPro Multi 4 question
    I have 2 questions on using Cellpro Multi4 (new to this)
    Bought the above charger after advice here ...
    Q1 Manual mentions that as well as the 20 loaded presets there are 50 more in a library ... are these documented somewhere so I can see what I could use?
    Q2 and this is probably pretty basic ... if I take NiMh I use as starter packs .. 2 of 3000mAh NiMh
    The only suitable preset would seem to be "NiMh fast charge with trickle" ... so I select this but have to set manually the charge rate ... charge rate for NiMH is 0.5C (or 1C if you want faster charge) ... which means I should charge at 1.5A .... is this correct ?
    If I charge at lower rate .. is the only disadvantage the time taken. most batteries last longer on lower current charge.
    I have been charging at 1.0A ..... speed of charge is not a requirement.
    Some people will always find fault - if you find a typo, consider it put there for you.
    I am afraid I can't help with Q1 as I have no experience of the charger.
    Q2. You are spot on.
      This may help to answer Q1 ?
      I have only read the main part of THIS POST and it looks like you have to use the usb interface and a pc to get the extra 50 presets.
      There is also a link in there giving more info, but I've not read it. Maybe it will tell you what you need to know.
      Good luck.
