Nine Eagles 210 A Coaxial help
  • Nine Eagles 210 A Coaxial help
    Hi first off not sure if this is the right place, rebuilding the above, got all the bits, and when it all goes together, 2 problems:
    1) The swash plate just sort of hangs off the servo arms and as no positive location and doesn't even fit on the shaft properly.
    2) The lower blade holder has no location on the main shaft.
    Any help pictures etc would be great
    Lee
    Probably a bit late and you've either sorted or binned it but have you got manual for it? If not try google and see if there is one you can download. I don't know heli so can't really give any more clues. Good luck, Steve
      The swash plate and lower blade holder have to be fixed to the outer shaft. The upper blades are fixed. They and the flybar are driven by the inner shaft.
      Having said that, this is how most co-axial helis work. I don't have any specific knowledge of your model.
