Hi,
First time post, but lurking for a while trying to glean as much info as I can!
So I bought RF7 sim a couple of months ago with the Interlink Elite controller (wish I had gone a different route now - hindsight
) and I am learning orientations (following the info from ArchMageAU on Helifreaks) and can now do slow upright auto-piros CW and CCW (using trim) without crashing. In playtime, I am bashing about (attempting) flips and rolls and playing with free flight movement - mostly way out of control - attempting circles and 8's.
The problem I have is the interlink Elite controller is so sensitive on the pitch/throttle that whenever I make a rudder adjustment, the pitch changes also, to the point that it is causing me to crash, fly away, or at least be out of control. Using pinch method helps, but not much. I am guessing that a "real" transmitter will not be as sensitive to my rudder movements. The Interlink elite controller is so loose! (I'm not going to elaborate on how loose!
I have also purchased a second hand 130x with spare batteries but wanted to get basics out of the way on the sim before I give that a go and endanger any plant life.
So which transmitter for a beginner? I can get a DX6i new for £80 but I see lots of posts saying the transmitter is the most important purchase! So should I go for a DX8/9 (as a beginner) for the extra £150-£200 or do all my sim and IRL flying with a DX6i until I gain better skills? I know there are good DX8 deals out there, but most second hand offerings I have seen are closer to the new price that it makes sense to buy new.
I'm leaning towards the DX6i as it will be a while before I would probably get any benefit from a DX8/9.
Any thoughts/advice appreciated
Alex
) and I am learning orientations (following the info from ArchMageAU on Helifreaks) and can now do slow upright auto-piros CW and CCW (using trim) without crashing. In playtime, I am bashing about (attempting) flips and rolls and playing with free flight movement - mostly way out of control - attempting circles and 8's.The problem I have is the interlink Elite controller is so sensitive on the pitch/throttle that whenever I make a rudder adjustment, the pitch changes also, to the point that it is causing me to crash, fly away, or at least be out of control. Using pinch method helps, but not much. I am guessing that a "real" transmitter will not be as sensitive to my rudder movements. The Interlink elite controller is so loose! (I'm not going to elaborate on how loose!
)I have also purchased a second hand 130x with spare batteries but wanted to get basics out of the way on the sim before I give that a go and endanger any plant life.
Alex
(other search engines are available)
- she is sat not to far away, within striking distance
