Hi Guys,
Got my new mcpx v2 yesterday and have some problems.
I brought the BNF version and have a new Dx6i. I then followed 'Finless Bobs beginner set up. All switches set to 0, have not bothered with the 1 setting yet,so I presume its just factory settings at the moment.
I then watched many Youtube Videos and bound them together,all good.
I have the idle up switch off so more beginner friendly too.F mode on that switch means Idle up is on and when the switch is switched to Gear this means idle off and your in normal/beginner mode?
I had the battery fully charged,switch off the throttle hold switch and eased on the throttle,I went up to full throttle and it never left the ground! Seems as though there was a lack of power?
I then decided to try to take of with the f mode switch on,idle up right?
All set in idle up mode I then took the throttle hold switch off.With the throttle lever FULLY DOWN the motor start to run on their own????
I have watched every set up video going, I must be as thick as a plank Lads, I'm at a loss.
Any help very much appreciated
