Heli spooling--when throttle stick at 0
This topic is closed.
  • Heli spooling--when throttle stick at 0
    Hi all,
    have a strange situation here....
    when I move the throttle stick up the heli starts spooling up, however when I bring it back to zero it still keeps on spinning.....wont stop until I use the throttle cut. checked all the wires in the rx and gyro.....everything looks fine.
    radio setup: u= up, d= down, r= right, l= left
    TRAVEL ADJUST
    THRO U 100% D 123% AILE L 100% R 100%
    ELEV U 100% D 100% RUDD L 120% R 100%
    GYRO U 100% D 100% PITC U 100% D 100%
    THRO CUR : %
    Norm (Pos L,2,3,4,H) 0,85,85,85,85
    Stunt mode (Pos L,2,3,4,H) 95,95,95,95,95
    Hold mode (Pos L,2,3,4,H) -0.0%
    SUB TRIM
    THRO 0 AILE 0
    ELEV 0 RUDD 0
    GYRO 0 PITC 0
    Please note that this setting was done by pro pilot........and using the above setting the heli was flying perfect........did not change anything in the radio after he set it up.....
    Using a Dx6i
    Would be great if anyone could shed some light on this issue.
    regards
    md
    (Fresh Beginner)
    You have some odd number there? Rudder you won't the same both sides
    make sure throttle curve is 0-100
    if spectrum rebind and make sure throttle is at bottom. Check throttle trim lever also
    Santander Factory Team
    Proud wearer of 5 x EGS
      Looks like your bottom stick position in your travel adjust for throttle is set to 100% and top is 123%. You want bottom to be set to 0%
      Stainburn Helicopter Club
      Sab Goblin Black Nitro 650
      MSH Protos 380
      Vbar Control
        Re-calibrate the esc for throttle movement.
        Proud owner of 3 EGS
          this is my throttle curve......
          THRO CUR : %
          (Fresh Beginner)
            guys I have edited the information above......
            (Fresh Beginner)
              hello mate have a look at my settings again I have edited it, hope it makes more sense now......I think up is 100% and bottom is 123%
              (Fresh Beginner)
                mate total noob here...using the mini titan stock esc I think it cannot be recalibrated...
                (Fresh Beginner)
                  Originally posted by Md001 View Post
                  Hi all,
                  TRAVEL ADJUST
                  THRO U 100% D 123% AILE L 100% R 100% make the 123% back to 100% and try again
                  THRO CUR : %
                  SUB TRIM
                  THRO 0 AILE 0
                  ELEV 0 RUDD 0
                  GYRO 0 PITC 0
                  Using a Dx6i
                  regards
                  md
                  alter to above
                    Mate I did that.....looks like the throttle cut wont work...and when I flick the throttle cut the heli keep on spinning..
                    but I observed one thing when using U 100% and D 123%..........the spooling seems to slow down when I increase the D figure (D 123%- D 125%) but the problem is maximum limit is 125% and I cant go further.......
                    alter to above
                    (Fresh Beginner)
                      Where is throttle trim on your tx screen ? If in middle slide to bottom , then try again
                        Ok my throttle trim on the radio was in the middle, but I had to do 6 clicks downward to make the spooling stop.............................Now if you could explain me why was it working properly before with the trim at the middle....and now why do I have to do 6 clicks down in order to make the spooling stop???
                        Also keeping the setting like this will if effect any other things meaning is it safe to use the helicopter like this????
                        (Fresh Beginner)
                          If that was anitro model it's like a tick over trim.
                          pull the trim all way to bottom and rebind,
                            Also put your rudder 100 100, otherwise will be faster one way
                              i still did not master the helicopter tail setup....so for now i wanna leave the rudder as it is because i wont be able to fix it if something goes wrong.....it was set up like this by that dude for some reason maybe....i did see there is little bit of left trim in the rudder on my radio. but to be honest i am not comfortable with changing anything on the tail.
                              gixer thank you so much for solving my problem.......but you still did not explain why did i have to use the trim in my radio????
                              (Fresh Beginner)
