This week I'm going try to get to the route of the tail drift so just need to know what heli that's effected, if your using sub trim possition of 3GX.
I have tail drift on my 450v2 but not on my 500 elf both use sub trim so I think it rulls that out but I now know 3GX stores sub trim in its memory so if you setup your heli with sub trim this can be set back to tx default once you've gone through 3GX v2 DIR mode so what im thying to work if i try the above will i still have tail drift i also know that you cannot use sub trim outside DIR mode 3gx doesn't like this so i've few other ideas of correcting tail drift which weather permitting will have an answer sometime this week will keep you all post.
