Ok dudes my OS91SX c spec viper bearings are sha**ed. has anyone installed ceramic bearings in one of these engines? if so what is the benefit and where is the best place to get them?
Many thanks in advance.
Lee
Trex 700 LE, 610's cyclic. Vbar, Radix mains, OS105HZ
it's really not worth putting a ceramic bearing in an engine as its the races that get pitted and make it rough, in addition to that the ceramic balls and shatter and pretty much destroy the engine from what i've heard, just put a decent bearing like a stainless skf one and it'll last for a while
DON'T DO IT! ceramic bearings'l shatter mate if you want to go with sumut differant i would reccomend full stainless (3c), cearfully pop out the poly shields first tho!
Use them no rust! normal steel cage's can corrode and fail not so likely with a stainless one
GAUI X7 Beast X V3 (a nice bit of fish!)
Trex600n Fbl ys56sr BeastX V3
Trex500Fbl AR7200BX
Trex500 Apache x4bld BeastX. Trex 600E HIND mil x5bld BeastX
DX7se
