Just wondering how and where you guys are mounting your header tanks on your 600's? Unsure where the best place to mount it would be on my super pro? Piccys would be great
thanks
Lee
I've also posted a picture of how I fitted my CSM 720. Unfortually if you fit it on top of the cyclic servos it fouls the canopy. You also have to mount it with a thick piece of mounting foam or else it induces tail creep. I know you didn't ask for this but it may be helpful if you are using a 720
Thanks for that Matt, ive done pretty much the same thing now but mine is a little further to the back of the heli. I dont suppose it will matter as long as its in line with the carb. Drilled my own hole then mounted the header with a long bolt a spacer similar to yours and a nylok nut. Seems as if i can push it back a forth a little too much and i like mine mounted tight. Will have to look into that. Im using a spartan 760 and have mounted mine on the gyro mount above the servos. Obviously i can get away with it because the gyro is so small.
My header tank is stuck to the side of the main tank with double sided tape, the perimeter of the joint sealed with Zap-A-Dap-A-Goo. This has survived many months and you can still lift the heli up with the header tank
Steve H
